robrajcs's avatar
robrajcs
Wifi off after router restart or power outage Netgear R6400
After a router restart, or power outage my wifi goes off disabled.
I must turn it on with the app or pushing the wifi button on the router
I think normally it should be at its previous state after restart or outage
Is there a setting to solve this problem?
Thank you
  • plemans's avatar
    which firmware version are you on?
    Hve you tried a factory reset and reinstall on it?
    • robrajcs's avatar
      robrajcs
      Firmware version: V1.0.1.62_1.0.4
      I did not do factory reset.
      • plemans's avatar
        I haven't heard of that issue with that specific firmware. maybe try re-installing the firmware and then a factory reset/reinstall. maybe something corrupt in the firmware.
