cderrington's avatar
Oct 25, 2017
WiFi set up Recommendations with three R6300v2's
Hi Folks, My buddy bought and I'm setting up three R6300v2 routers at his nightclub to replace two OLD WiFi routers.  He bought the R6300v2 so he could use the Facebook WiFi "check-in thingy".   I'...
  • michaelkenward's avatar
    michaelkenward
    Oct 26, 2017
    cderrington wrote:
    Do you know what settings I should turn off to put the least amount of stress on the CPU and RAM of the "main" router?
    I've never seen any suggestion here that this is an issue with this sort of hardware.
    You may be creating a problem for yourself that doesn't exist.
    Suck it and see is my advice.
