Cimbian
Apr 18, 2017Aspirant
wifi to LAN bridge
I have recently moved from having a separate office to having one in my rented house. The internet is supplied by Sky through one of their modem/routers and it works...ish. My router is downs...
- Apr 26, 2017
To close the loop on this thread. I bought a TL-WA860RE and that seems to work just fine in this role.
I never did find a Netgear solution.
netwrks
Apr 18, 2017Master
Try a powerline solution (google search) to go from the router to your switch. You could hang a WAP off of the switch if required.. Also, use minimum CAT5e cables.
