Cimbian
Apr 18, 2017Aspirant
wifi to LAN bridge
I have recently moved from having a separate office to having one in my rented house. The internet is supplied by Sky through one of their modem/routers and it works...ish. My router is downs...
- Apr 26, 2017
To close the loop on this thread. I bought a TL-WA860RE and that seems to work just fine in this role.
I never did find a Netgear solution.
michaelkenward
Apr 19, 2017Guru - Experienced User
Cimbian wrote:
I already have a TP Link power line system, which works, but it drops connection several times a day and it seems to be a known issue.
I would investigate that. What does "a known issue" mean?
Powerline would be a more reliable solution than wifi. Maybe you just need better plugs.
Powerline technology has come a long way in recent years. You can now get plugs that have 1000BASE-Tx LAN. First generation was 100BASE-Tx at best.
You could even get a pair of plugs that delivers wifi to the office as qell as the LAN.
Cimbian
Apr 19, 2017Aspirant
Hi,
I have a TL-WPA8630PKIT Gigabit setup and the forums report the dropouts to be very common, over several generations. Many have contacted TP-LINK but the problem persists.
My plug sockets are direct, no extensions or multiways and the TL-WPA8630PKIT is a wireless plus LAN unit, the reason I bought them. When it is working, it works very well, but the dropouts are a significant issue for me as I work from home and use a VOIP system for the phone.
Wireless is not an option for the number of non-wireless devices I have. I need something to connect to a switch, or similar.
Steve.
