Nishanth's avatar
Nishanth
Initiate
May 24, 2017
Will Amazon Fire Stick work
Hello,   Will my router(R6220) work with Amazon Fire Stick connected to TV to play media from Hard Drive connected to the Router?   Thanks
  • DexterJB's avatar
    May 24, 2017
    Hi Nishanth,
    Please check the Fire Stick specs and make sure it supports DLNA. If yes, then it should work.
    Dexter
    Community Team
