Nishanth
May 24, 2017Initiate
Will Amazon Fire Stick work
Hello, Will my router(R6220) work with Amazon Fire Stick connected to TV to play media from Hard Drive connected to the Router? Thanks
DexterJB
May 24, 2017NETGEAR Moderator
Hi Nishanth,
Please check the Fire Stick specs and make sure it supports DLNA. If yes, then it should work.
Dexter
Community Team
Nishanth
May 25, 2017Initiate
Thanks for the reply, I do have another query. Under router management settings through browser I can see there is an option to Turn ON/OFF Remote Management, but when I try to turnn on Remote Access in Genie App, it says not supported. Why so? Does this router model supports remote management from outside home network.
Thanks
