caisson1
Feb 11, 2024Aspirant
Windows 10 does not recognize USB Flash drive From Nighthawk r8000
The USB is a Sandisk Ultra USB 3.0 Flash Drive, 512GB. Windows 10 File Explorer does not recognize the drive from the router's 2.0 or 3.0 port. The R8000 Firmware Version is the latest: V1.0.4.84_10.1.84. From the router's Basic and Advanced settings page, I see the the share name as \\readyshare\T_Drive and folder is T:\.
In addition the recent log shows [USB device attached] The USB storage device USB SanDisk 3.2Gen1 (New Volume) is attached to the Sunday, Feb 11,2024 07:38:07
If I plug the USB into my windows computer it immediately pops up as New Volume (T:) in explorer and I can write files to the flash drive. Also, I can view the USB in Disk Management and I have reformatted it to NTFS successfully.
Anyone have an idea what the problem is?
Thanks for the replies. I found a solution.
- Select Start > Run and enter \\readyshare in the dialog box.
Click OK. - Right click the drive and select Map Network Drive
- microchip8MasterYou need to enable SMB1 in Windows.
microchip8 wrote:
You need to enable SMB1 in Windows.Here's what to do.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
- caisson1Aspirant
I enabled SMB 1 and now the drive doesn't show up when I log in to the router nor in file explorer.
