LoganConnell's avatar
LoganConnell
Windows 10 PC Can't Connect to R6400 Router
Hey,   I just installed this new router today instead of the virgin media superhub 2. It started off great, had no problems installing and everything seemed to connect fine.   After everything wa...
  • LoganConnell's avatar
    Nov 28, 2016
    Solved!
    This was fixed by changing the channel in the router settings to 2Ghz = 09 and 5Ghz = 36
    Due to interference in the area.
