LawDown's avatar
LawDown
Follower
Nov 16, 2021
Windows 11
Is this router appropriate for for Windows 11?
  • FURRYe38's avatar
    Windows isn't really dependent upon router brand or model. Most routers work with most PC platforms.
    Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
    Thank you
  • michaelkenward's avatar
    michaelkenward
    There's nothing on a router that has anything to do with Windows.
    Mostly you use the browser graphical user interface (GUI) and any browser will do.
    Windows might affect things like the desktop apps that we use. I can confirm that the Windows Genie and the ReadyCLOIUD app both work happily in Windows.
    PS If you are puzzled as to why someone should dredge up their boilerplate text to tell you that your router has nothing to do with the operating system and then tell you to take your question elsewhere, that makes two of us. The answer there will be the same as the answer here.
