jj8279's avatar
jj8279
Initiate
Feb 27, 2023
WINDR4500 V2
Hi.  I have an older WINDR4500V2 router, primarily used as a secondary router for my wireseless security cameras.  Is there any way to remotely login to this router?  The nighthawk app claims the router is too old and I struggle to find a way.
Thank you.
  • plemans's avatar
    is it setup in router mode or access point mode?
    (if its a secondary router, it should be in access point mode)
    What I usually do is remote into a computer on my network and use that to access the ip address of the router. Tends to be the fastest
    • jj8279's avatar
      jj8279
      Initiate
      I'm not 100% sure and at work at the moment but I think router mode.  I will definitely check when I get home.
      Perfect.  Thank You!
  • michaelkenward's avatar
    michaelkenward
    What do you want to do with remote login?
    Your decade old router certainly predates most of the easily accessed features.
