EJBsf
Jun 29, 2016Star
Wireless repeater function missing - now what do I do?
I just moved to a new place. The front and back of the apt are a fair distance from each other. The N750 router's in the back of the building, wifi is weak in the front. Stringing ethernet cable is n...
- Jun 30, 2016
Thanks for the replies. Consensus seems to be the powerline solution. I've ordered a set and will see what happens.
EdB
michaelkenward
Jun 30, 2016Guru - Experienced User
TheEther wrote:
Install a Powerline network in lieu of stringing Ethernet. Then connect the N600 and N750 to it. Reconfigure the N600 as an Access Point.
That was my choice. Powerline has come a long way in the last few years.
You don't say what you want to do on the "remote" devices. I stream TV over powerline. Few demands are more severe than that.
EJBsf
Jun 30, 2016Star
EdB
