sjkruger
Jul 31, 2018Aspirant
wireless router not working
I have a hard ethernet line running from my Arris Surfboard modem through this Model WNR2000v5 (not listed in drop down box) router to my PC, and the internet on the PC is working fine. However, my ...
- Jul 31, 2018
found the "hidden" factory reset button.
Factory reset resolved this issue, I'm up and running.
sjkruger
- antinodeJul 31, 2018Guru
> [...] Model WNR2000v5 (not listed in drop down box) [...]
Wrong forum.
https://community.netgear.com/t5/x/bd-p/home-wifi-routers-wireless-n
For the record:
> [...] There is no button on this router.
Where did you look? Visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual. Look
for "Factory Settings".
