hendja
Sep 16, 2015Aspirant
Wireless router
I have had a N900 wireless router for 3 months. It ran out of tech support one week ago and quit connecting to wireless then. I called Tech Support and they did some testing and said that there was nothing wrong with the hardware but the router wasn't 'communicating'. They wanted to charge me $89 to extend my tech support.
I have:
connected directly to the internet
reset factory defaults
turned the router off and on multiple times
How can I get the router to communicate again? Please help!
- Everything is working great!
- hendjaAspirantEverything is working great!
- ElaineMNETGEAR Employee Retired
- hendjaAspirant
P>S> Elaine--I do have internet access when I plug my modem directly into my computer. I am just having trouble with the wireless router.
hendja Check this link on how to get into the router settings. I assume that when you say wireless router that means whole router not just the wireless portion of the router. If that's the case, reset the router by pushing the reset button on the router for 10 seconds. After reset, follow the instructions that was given previously to reconfigure the router.
Looking forward to your response.
- hendjaAspirant
Elaine--
I am trying this. I have downloaded the firmware and installation instructions. But http://www.routerlogin.net/ won't open for me to login and continue. I am hoping the site is just down. I will continue trying. Thank you SO much for trying to help me.
