MickeyFlint's avatar
MickeyFlint
Follower
Apr 06, 2021
WN2500RPv2 Factory reset now wont see http://mywifiext
So I moved and wanted to reset this up after having used it a few years at my old place. I did the push button factory reset on it and now (as per the setup guide) have connected both wirelessly and wired but neither seem to access when I put in http://mywifiext
I have tried chrome, firefox and edge. I have dissabled all of my firewalls when I try to do this.
I have good LED on power and on the etherenet port I am connected to.
I have tried disabling firest the ethernet and then the wifi addapters to issolate one over the other and neither is connecting.
I am stupped. Should I be throwing this in the trash?
Thanks
  • plemans's avatar
    Try this.
    Factory reset it 1 more time.
    Push and hold reset for 7-15 seconds while its powered on.
    Then during setup, hardwire a pc/laptop into it. Disable the wifi on the pc/laptop to ensure it doesn't default back to the wifi.
    Then try the mywifiext  .  net   (take the spaces out)  or try 192.168.1.250   (default ip address)
  • > [...] neither seem to access when I put in http://mywifiext
       Did you actually put in "http://mywifiext", or did you put in what's
    in the documentation?  (For no apparent reason, "mywifiXext.net" without
    the "X" is forbidden in these forums.)
       A clear description of what _does_ happen would be more useful than a
    vague description of what does _not_ happen.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot"?
    • diverjerR's avatar
      diverjerR
      I was not able to get connected to my EX2700 extender using the IP address I know was right as I double check it always from the tablet which is connected to the extender.  My router does dynamic addressing and I set the range.
      I finely got connected to the extender by using that URL this site doesn't want to be displayed.  The one that starts with (mywifi) I didn't change anything, but it connected and worked as it should and use to when only using the IP address of extender which is easy to find.  I know I could assign extender an IP, but it is easy to find.  I did notice when using that mywifi...... URL browser puts the HTTP:// in front.  If I change the HTTP to HTTPS:// with the mywifi..............  I get the same error as when I use only an IP address, which is unable to reach device.  Error a little different in all 3 browsers I tried, but means the same.
      • antinode's avatar
        antinode
        Guru
        > I was not able to get connected to my EX2700 extender [...]
           "not able" is not a useful problem description.  It does not say
        what you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
        > [...] using the IP address I know was right as I double check it
        > always from the tablet which is connected to the extender. [...]
           It's nice that you're happy, but I can't see your "the IP address I
        know was right", and I have no idea how you "double check it". I do
        know that specifying a wrong IP address is a good way to get a failure.
           People come to these forums every day, claiming to "know" something
        which isn't true.  Such experience leads to skepticism about any claim
        which includes "I know", but no actual evidence.
        > [...] If I change the HTTP to HTTPS:// with the mywifi..............
        > to reach device. [...]
           These devices are too simple to use HTTPS ("https://<whatever>").
        With some browsers, you might need to specify "http://" explicitly.
           And what happens if you specify some known-wrong IP address?
