SkareKrow's avatar
SkareKrow
WNDR 3800 how to create a schedule for 2.4GHz Guest Network and allow 2.4Ghz home network to work.
I have a WNDR 3800.
I can creat a schedule to turn off the internet from time (a) to time (b)
Pretty much have family at home that I do not want using the wifi after 10:30Pm (Sister in law/ Mother in law get your butt to bed).
But I would like to continue to use my wifi personally. I know I could do 2.4ghz scheduling and 5Ghz scheduling but the issue is that the Toshiba Satellite has an older wifi radio. Only reads 2.4Ghz But phones,tablets,phablets etc... do read the 5ghz. But I would like to continue playing my video games etc... After midnight when my kids are asleep.
Any possible way to have both 2.4ghz networks running (home wifi & guest network wifi) but schedule to turn off the wifi connection to the Guest network at a certain time.
Thank you kindly in advance.
  • Putting any potential arguments aside, I think the easiest thing you can do is;
    Use DHCP Address Reservation so that the same IP address is always allocated to the target devices (you might need to find out their MAC addresses but that should not be too difficult. In the router’s Connected Devices list you should see the MAC addresses of all currently connected devices, there are Internet sites for MAC Address Lookup which can help identify the device manufacturer.
    When you have reserved an IP address for the devices, use the router’s ‘Block Services Setup’ to block all Internet access to selected devices, then apply a schedule to that blocked service.
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    • SkareKrow's avatar
      SkareKrow
      Awesome thank you for your quick response. I thought of doing this. I just liked the fact that the network disappears on the on/off schedule. But I guess this is the only route to go with this Router. Thanks kindly once again.
