steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
steveincolorado
Jan 03, 2015Novice
UPDATE:
Now I'm having to power cycle the router ever 90 minutes. I lose connectivity on both radio's (2.5GHz and 5.0GHz) as well as over the Ethernet LAN ports.
This router powers my phone besides my regular Internet. I need this to work and work reliably. The router is only 13 months old.
Any suggestions?
Thanks
Steve
Any suggestions?
Thanks
Steve
