steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
Fairytail
Jan 28, 2015Virtuoso
Please check the modem. Connect your computer directly to the modem and observe the connection. If the modem disconnects then you need to call ISP but if the connection is stable then you should contact NETGEAR again.
