steveincolorado's avatar
Jan 02, 2015
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
  • steveincolorado's avatar
    Feb 28, 2015
    The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
    Thanks anyway.
    Steve
