steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
thadguidry
Mar 15, 2015Novice
I also get the same issue where the Wireless Radio and Lan lose the connection.
And have done extensive testing.
The wireless iPad is able to see the SSID, but when clicked it gives a message "cannot connect to network". When I turn my computer on and look at the network connection, the LAN connection shows the troubleshooting sign.
I am able to simply reboot the Netgear WNDR4300 and both my devices then connect to the internet.
My thoughts are that perhaps something IS happening to our ISP, but then quickly resolves itself...but the Netgear WNDR4300 does not automatically resolve the ISP connection again. Is there a missing option that needs to be added or checked somewhere ?
