steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
mrayn5
Mar 26, 2015Novice
I am experiencing the same issue, although I only lose the 2.4Ghz band. Wired connections and 5Ghz stay connected to the router and the internet. Only a reboot of the device gets the 2.4Ghz connections to re-establish. Not sure what has changed, but it sure seems like something has.
