steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
peteymit
Apr 07, 2015Novice
I bought an N750 based on the Consumer Reports suggestion and this happened to me already. The router wasn't running for 48 hours and the 2.4Ghz signal went completely out after working for about the previous 24 hours. I changed just about every setting imaginable without rebooting and it made no difference. Rebooted and it's back on now. Hopefully that helps diagnose.
