steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
Kloas
Apr 30, 2015Aspirant
Do you have Guest-wifi or 5GHz-wifi disabled?
My problem disappeared after enabling both wifi-radio's
