steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
Nsharra
May 01, 2015Initiate
I am having the same issue. Many times a reboot makes no difference. It seems the 2.4 cannot stay connected to anything anymore. The devices that can connect to both 2.4 & 5 always kick over to the 5ghz. The devices that cannot connect to 5, just disconnect altogether.
I updated the firmware, disabled and enabled wireless settings, and changed channels as well. Still makes no difference.
Help, please.
Help, please.
