steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
lurzan
May 08, 2015Novice
The WNDR4300 is having a new firmware update v1.0.2.78. If the router is not detecting the new firmware automatically, download and manually upload the new firmware from the link
http://downloadcenter.netgear.com/en/product/WNDR4300#searchResults
http://kb.netgear.com/app/answers/detail/a_id/23960
After installing the new firmware. Make sure to take the backup of the current setting of the router and do a soft reset to the router and reconfigured
