steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
meanhacker
Jul 14, 2015Aspirant
My 2.4Ghz band also keeps dropping out almost every day. I have to reboot the router. I just updated the firmware from V1.0.2.78 to V1.0.2.80 and will see how this one works out.
- magna_eliteAug 01, 2015Aspirant
How did the latest firmware work out for you? I am also having the dropped wifi symptom, it's really frustrating.
