steveincolorado
Jan 02, 2015Novice
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. ...
- Feb 28, 2015The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
Thanks anyway.
Steve
DR5150
Sep 17, 2015Aspirant
Has anyone seen any good results on this?
I am on a WNDR 4300 v1 with 1.0.2.80 firmware.
I have used wifi analyzer to identify that channel 11 for 2.4 is not being used in my nearby area.
Still daily the 2.4 radio drops, while the 5 continues to function.
I have made sure that the guest networks are turned on
I am trying to revert back to firmware 1.0.1.42 to see if that helps
- ElaineMSep 18, 2015NETGEAR Employee Retired
DR5150 Try setting the Fragmentation Length and RTS/CTS Threshold to 2304 under 2.4Ghz settings which can be found under Advanced > Advanced Setup > Wireless Settings.
After adjusting the settings, reconnect your 2.4Ghz devices and observe your connection.
Let us know what happens.
