Ranok
Dec 02, 2016Aspirant
WNDR 4500 not set up correctly
I have a problem with internet stability when browsing and connecting to league of legends. I was in chats with riot support and they told me it looked like I was using two routers and the second o...
- Dec 06, 2016
Looking at the link you provided, your modem is also a router.
Your NETGEAR is a router therefore you have two routers.
What you can do is call your ISP and have them set your surfboard modem to be in modem only.
Once done, configure the router for Cable Connection then observe if your internet will still drop.
ElaineM
Dec 05, 2016NETGEAR Employee Retired
Welcome to the community, Ranok
What's the brand of the modem that you have?
If you can set the modem be in bridge, please do so and then verify your connection.
If you have 2 routers running then most likely you will really have problems playing a game.
Once you have configured the modem be in bridge mode then you will need to make sure that all ports for the game are properly forwarded to the router. See the link below for more information.
How do I configure port forwarding on routers with the NETGEAR genie interface?
Ranok
Dec 05, 2016Aspirant
I do not have two routers but I was told it seemed I did. I only have the modem and 1 router.
