rtbala
Feb 05, 2022Aspirant
wndr 4700 connect telnet
Hello. I need to telnet to my WNDR 4700. The firmware version is V1.0.0.56.
To do this, I downloaded telnetenable.exe and used it.
The port scanner shows that port 23 is open.
But when using the "telnet ip address of the router" command,
the connection does not occur. Please help me to connect.
Netgear has set up a community forum specifically for Smart WiFi Router products. Most of the people who watch that forum are more likely to have experience with older routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you - FURRYe38Guru - Experienced User
Any progress on this?
