Solvenet's avatar
Solvenet
WNDR3400 as ethernet switch paired with T-Mobile gateway (2023) TMO-G4AR
Greetings.
Recently joined T-Mobile home internet (it was good deal).   T-provides a gateway that only comes with two ethernet output ports.   For security reasons, I prefer to use wired connection on some devices.   Thought of using my Netgear WNDR3400 as ethernet switch port.   (I used to do that with AT&T's wired router, NO PROBLEM, no loss of speed).   Unfortunately, I do experience loss of speed in with T-Mobile.  The T-Mobile gateway is able to produce download speed of 128 Mbps downloads (either connected directly or over wifi).   If I put the Netgear router in-between as a ethernet switch, the computer download speed clocks at 75 Mbps downloads.  The specs of the WNDR3400 say it should be able to hande 300 Mbps; so I thought 128 should be no problem.
Thoughts?
Does anyone know if (even though) it is marketed to be able to handle 300Mbps, the design may be limited???
Will appreciate knowledge to be able to keep the 128 Mbps that the T-mobile gateway produces (when connected directly).   Thank you all.
  • Does it have 100 Mbps LAN ports? If so, wired you won't get much more. The 300 Mbps is for WiFi
    • Solvenet's avatar
      Solvenet
      GOOD point.  It does have 100Mpbs LAN ports, but It is not reaching 100Mbps.   It gets to 75 Mbps (which is better than the 50 Mbps I used get with AT&T).
      Question: Shouldn't the LAN port deliver then 100Mbps instead of the 75 it is????    By the way, also the WiFi through the Netgear router is NOT delivering the speed it gets from the gateway.    Again, items connected directly to the TMobile gateway (WiFi or wired, both) get download speeds at 128 Mbps.   But anything connected indirectly via the Netgear router is well below  (75mpbs if wired, and the WiFi even lower than that).     None of this used to happen when equally connected to an AT&T router.
      Advice?  Thoughts?
      Thanks.
      • microchip8's avatar
        microchip8
        Master
        In which mode is the NETGEAR device? Router or Access Point? If you're piling up router after router, it can reduce the throughput
