ahmednageeb's avatar
ahmednageeb
WNDR3400 can't connect to readyshare on android
i have netgear n600 WNDR3400 router with built in samba server aka readyshare when i connect my windows and mac laptops i login in to my hhd no problem but on my android device i used many apps like es file explorer and same result i get i can't connect it require username and password but the pc doesnt and there is no options to configure that on the router any solution???? and i downloaded the genie app but i can't connect to the router ??? any solution ?? Thanks in advance
  • Hi ahmednageeb,
    1. What is the firmware version of the router?
    2. Have you tried using another device (another Android, iOS)?
    3. You may refer to the apps' support/dev on how to configure the app since it works with your other devices.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ahmednageeb,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi ahmednageeb,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
