tman1's avatar
tman1
WNDR3400 shows Not conneceted on Genie
On a weekly basis, Netgear Genie indicates WiFi Connection status as: "Not Connected". However, all of my devices continue to work with WiFi. I don't understand what the Genie message is indicating.
    Hi tman1,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi tman1,
    If you are viewing the NETGEAR Genie on a non-wireless capable device (Ethernet only) then it is normal since that will only indicate as "Connected" if the device where the Genie app is installed is connected via WiFi/wireless.
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi tman1,
      Dexter
      Community Team
      • tman1's avatar
        tman1
        Thanks. I now understand why I was getting the message in Genie.
