MitchPatenaude
Sep 15, 2016Follower
WNDR3400 support for Gigabit Ethernet on LAN side?
I'm trying to figure out if the WNDR3400 (v2) supports gigabit ethernet on the LAN side. The Tech specs here seem to suggest that it's only 10/100, but the diagram labels them as gigabit. So which is it?
The manual and the data sheet indicate up to 100 Mbps
From the manual: LAN 10BASE-T or 100BASE-Tx, RJ-45 WAN 10BASE-T or 100BASE-Tx, RJ-45.
Short of plugging into a LAN port with a 1000Mbps NIC card and CAT5e cable to verify connected speed, I wold go with what the manual shows.
1 Reply
- netwrksMaster
