ken63w
Apr 26, 2016Aspirant
WNDR3400; wireless operation stops frequently requiring the wireless settings to be re-applied.
- ElaineMNETGEAR Employee Retired
Hello ken63w
Welcome to the community!
What model version do you have? What wireless devices are affected? All wireless devices are affected? Which wireless signal (2.4GHz/5GHz) you're connecting to?
How's your wired connection? Is it stable?
Are there any other wireless devices that may cause interference with the wireless connection? Make sure to avoid microwave ovens, baby monitors, cordless phones, and the likes.
Do you have the latest firmware installed? If not, kindly upgrade to the latest firmware then do not forget to factory reset the router.
You will have to use a paperclip to push the reset button at the back of it for 10 seconds.
After reset, reconfigure the router to get back the internet connection. Once you're up and running observe your connection.
- ken63wAspirant
ElaineM wrote:Hello ken63w
Thank you for your response to my problem. Here are answers to your
questions (as best I am able).Not sure of the model version, purchased new July of 2011.
All wireless devices affected.
2.4 GHz is normal connection.
The wired connection to my desk top Mac is stable.
Wireless devices are 2 iPhones, 2iPads, Sony TV and a Bose Soundtouch.
When I log in to Netgear I am told there are no firmware upgrades available.
Hope this helps.- ElaineMNETGEAR Employee Retired
- VE6CGXMaster
By any chance is your router running too hot?
