mattmer's avatar
mattmer
Tutor
Dec 31, 2021
WNDR3400/n600 v1 see ip camera on device list, cannot access
OK. I purchased an Ebay ip camera (360° Panoramic WiFi IP Camera E27 Light Bulb 1080P HD Wireless Security Camera | eBay). Cannot seem to connect to it. I've tried the ip address i see in the router (10.0.0.7), but nothing. That's where I'm at now. Tried usnig the steup instructions (Camera instructions (NEW) - YCC365 PLUS), but nada. I've turned the camera off and onmany times and only about 4 of those times did the ptz whirl around, stop and voiced something. Any ideas out there? I'm not a network/ip guy, just enough to get in deep trouble.
  • mattmer's avatar
    mattmer
    Jan 08, 2022
    The velop. All is working ok now. I got the camera added and installed. Just kept resetting the camera and trying. All so confusing.
  • plemans's avatar
    A couple things.
    1. you have the WNDR3400. what firmware is on it?
    2. What modem/gatweay is the router connected to?
    3. Its not the router that connects to the camera. Its the camera that connects to the router. If you're having issues getting it connected, try contacting the manufacturer
  • michaelkenward's avatar
    michaelkenward
    The original WNDR3400 is pretty old, from 2010. So it isn't really geared up for the onslaught of Internet of Things (IoT) toys that have appeared since then.
    But, as plemans says, you should start with the camera. The router just puffs out wifi. It is then down to the camera to play ball.
    If your router has given itself that address, rather than the default of 192.168.1.1, I'd look for a modem/router on front of it. If so, you can expect trouble.
    What is Double NAT? | Answer | NETGEAR Support
  • decided to upgrade router first with asus ac5300. As for camera, it was not resetting when powered on so could not add device. It's at least doing that and is recognised randomly. Good point is it's a camera problem though. I'll keep at it until ...
    • mattmer's avatar
      mattmer
      Tutor
      While I was checking out the new router, I gave this problem a new look. Turns out I've got a linksys Velop WHW03 router in front of the netgear. Now I have to figure a way to get a passthrough to connect to the netgear. I could connect to the velop but I want to view the camera on my desktop too. Back to the books. Evidently Phone guy came in and added this because our TV was having problems connecting to internet. I'm getting older and some things get lost in the cracks.
        michaelkenward
        The usual options when dealing with this "double NAT" situation is either to out the first router, the Velop WHW03 into bridge (modem only) mode, or the second router, the Netgear, into wireless access point (AP) mode. The manual tells you how to do that.
        Talk of "passthrough" mode, whatever you mean by that, is probably a red herring.
        Follow the strategy above and you will have just one router managing the traffic on your network. Then everything on your network should appear on whatever you use to access it.
        What is the "this" that the phone guy added?
