Vic73
Mar 27, 2017Aspirant
WNDR3400V2 keep dropping connection to wireless devices
Hello all, I have had my Netgear WNDR3400V2 for over 2 years and it has worked flawlessly up until this latest firmware update. It's now dropping all wireless connections every couple of minutes ho...
- Mar 27, 2017Hello wcalifas831, I've reset my router instead of rolling back to the previous firmware and it seems to have done the trick. Should my router start dropping connections to my wireless devices I will sure to do the above mentioned method. Thanks for the prompt response.
wcalifas831
Mar 27, 2017Prodigy
hi there, you should be able to revert back to the older firmware. Go to the netgear website and download section and find the firmware you had before. If it doesn't allow you through the manual update section on the router you can try doing it using tftp method. Let us know if you need help in doing that.
