LavaGoat's avatar
LavaGoat
Follower
Oct 16, 2017
WNDR3400v3 looses internet connection
Once every 2nd week I have to restart my wireless router (WNDR3400v3).
All devices connected (both wireless and with cable) loose internet connecton.
The device connected wireless are connected to the wireless network - but they don't get access to the internet.
I have the newest firmware version (V1.0.1.14_1.0.6) installed.
This has been going on for a long time. A restart (power off/on) of the ruter solves this. Just wonder if anyboyd has the same problem and maybe a permanent fix.
Radek
  • It can be a common thing with heavy usage. I see my router needs a power cycle every now and then when there's heavy usage. These routers aren't perfect and some tend to be power cycled more after periods of heavy usage.
1 Reply
