SSri's avatar
SSri
WNDR3400V3-N600 - Windows 10 Connectivity Issue
Hi, I have a new DELL Inspiron (Windows 10) with a "Intel Dual Band Wireless AC 3165" which I am unable to connect to WNDR3400V3-N600 router. Other existing devices like Android, iOS and Printer are ...
  • SSri's avatar
    SSri
    Jan 20, 2016
    Found the problem.
    I needed a hard reset of the Router after I had upgraded the router firmware sometime back. Everything is back to normal now.
    This can now be closed.
    Thanks Elaine, for your support.
