SSri
Jan 18, 2016Aspirant
WNDR3400V3-N600 - Windows 10 Connectivity Issue
Hi, I have a new DELL Inspiron (Windows 10) with a "Intel Dual Band Wireless AC 3165" which I am unable to connect to WNDR3400V3-N600 router. Other existing devices like Android, iOS and Printer are ...
- Jan 20, 2016
Found the problem.
I needed a hard reset of the Router after I had upgraded the router firmware sometime back. Everything is back to normal now.
This can now be closed.
Thanks Elaine, for your support.
ElaineM
Jan 19, 2016NETGEAR Employee Retired
Welcome to the community, SSri
That's very odd.
There's a new Intel driver version 18.30.0. It's release date was 12/16/2015.
Try to install that one and see if that will work.
Also, did you upgrade OS or your computer comes with Windows 10 already?
