JoylessFire's avatar
JoylessFire
WNDR3400v3: ps4 nat 3
I DO NOT HAVE THAT MODEL!!!! I HAVE A WNDR3400V3 WIFI ROUTER, BUT IT IS NOT LISTED AS A MODEL TO CHOOSE
Firmware Version
V1.0.1.4_1.0.52
I have the most recent firmware that i'm aware of, I have followed the steps listed in these two links:
http://www.playstationing.com/ps4/how-to-change-your-nat-type-on-ps4-and-ps3/839
https://www.bungie.net/en/Help/Article/11931
I have also set my PS4 to its own IP, i have it also setup with a direct connection through ethernet. i have turned on the default DMZ server to that IP, and have set the NAT filtering to Open, i have restarted my router and my playstation4, leaving them both off for over 2 min, and STILL am getting a Nat type 3. I have had this issue before, but have been ignoring it. I am wanting to have better online connections now, as I am playing more and more with friends, and want to get it fixed now. I have no other ideas to try to get this to work.
I have also made all of those listed ports set to be forwarded and triggered (as thats what my help center showed is used instead of opening ports).  I have talked to my ISP and i've done everything i can with them to make sure its not with them. i have no where else to turn, as i can't really blame my ps4, as i just bought it 2 weeks ago. I had a ps3 before that, and it still gave me nat 3, following the same instructions
  • Checked my most recent bill from them and they haven't been charging me for one, even though i asked specifically for one... I'll contact them when they're open and hopefully get it fixed
      • TheEther's avatar
        TheEther
        Guru
        Then you will need to either put it into bridge mode or equivalent such that your WNDR4700 receives a public IP address.  Or convert your WNDR4700 into an Access Point.  Or set up port forwarding on both the combo router + modem and the WNDR4700.
      • TheEther's avatar
        TheEther
        Guru
        I'm confused.  The WNDR3400V3 is a router.  It doesn't have a modem.  What is connected to the WNDR3400V3's Internet port?
        Let me ask another way.  Does the IP address of the WNDR3400V3's Internet port begin with either 192.168.x.x, 172.16.x.x, 10.x.x.x or 100.x.x.x?
  • Ok, 10.1.x.x is a private IP address. That means your ISP is performing NAT. If you don't have access to the ISP's box then you will have to call them and ask for a public IP address.
    • JoylessFire's avatar
      JoylessFire
