MasterOfLaws
Mar 31, 2016Aspirant
WNDR3700: how to create accespoint and general information
Hi, Hereby I would like to ask for your support regarding to my home network. Situation: For a couple of years I own the WNDR3700 router, which I use as a router. It's connected with a cable ...
- Apr 01, 2016
The WNDR3700 can be used as an Access Point, but only when it is physically wired to the main router. If your house is wired for Ethernet or you are able to install Ethernet (Powerline can used as an alternative), then you can enable AP Mode in the WNDR3700's setup via ADVANCED > Advanced Setup > Wireless AP.
Personally, I prefer and recommend an alternative form of setting a router up as an Access Point. It's an old school method that was used before Netgear added the AP Mode setting. My instructions for setting this up can be found in another thread (link). Note, in particular the difference in using a LAN port instead of the WAN port!
MasterOfLaws
Apr 01, 2016Aspirant
Thanks for your reply.
My goal is to use the wifi modem (1st floor) as a router so I will be able to get a good wifi signal on the first floor, while I use my router (second floor) as an acces point. So my goal isn't to boost the range of my current router, but to add an acces point to the construction which will give me two wireless connections and thus an increased range of my wireless network.
Thanks for your link. I already found it before I considered posting to the forum, but I doubted if it would apply to my model. I will try it though.
Can someone confirm if I can keep using the LAN ports? It seems that the link says that it's not possible: 'Its (the AP) sole purpose is to provide a wireless connection.'
TheEther
Apr 01, 2016Guru
- MasterOfLawsApr 01, 2016Aspirant
Yes, the acces point and the router will be physically wired to each other.
I am interested in your option, however I do not fully understand what's the advantage above the AP Mode that Netgear provides. So what will be de big difference in using your 'old school method' instead of Netgear's AP Mode?
Which way will give me the possibility to keep using my Acces point's LAN ports (for my PC and game console which are right next to my WNDR3700).
Thanks!
- TheEtherApr 02, 2016Guru
AP Mode on many, if not most, of Netgear's routers disable hardware acceleration. This can have a negative effect on network throughput through the access point. The old school method does not disable hardware acceleration.
Both methods allow the LAN ports to be used. There will be one less LAN port available with the old school method because it is used instead of the WAN port.
- MasterOfLawsApr 06, 2016Aspirant
Thanks!
I guess the old school method seems better regarding the hardware acceleration. Besides, it looks like the WNDR3700 does not support AP-mode (or maybe it does..). The steps ADVANCED > Advanced Setup > Wireless AP cannot be followed, since I cannot find the option 'advanced setup'. Other pages do not offer me the option to turn on wireless AP.
However, under Maintance > Router status > Wireless Port, I see that Wireless AP is turned 'on'.
An explanation about wireless AP is given in the sidebar:
- Wireless AP. Indicates if the access point feature of the router is enabled or not. If not enabled, the Wireless LED on the front panel is off.
So it seems that my AP mode was turned on already. However, I do not know how to turn it off or how I turned it on.
Do you know how I can turn AP mode off (and on) for my WNDR3700 (it seems like it has the latest firmware)?
My Netgear configuration screen does not look like the screenshots in this link, but like this (example):
