Goombahz
Feb 24, 2016Aspirant
WNDR3700 v1 firmware 1.0.16.98NA no LOGIN access
I've had this router for 6yrs and always found uses and solutions for it but this time I'm baffled. Following an ISP change I upgraded the firmware to 1.0.16.98NA as I was having the regular hang issues. I use the 3700 as a wired and wireless AP with a static IP address, lan to lan setup. Since the upgrade reboot, wired directly or not with a fresh reboot ol the laptop and router, I no longer am able to access the login screen and get the usual:
This webpage is not available
This being an old issue, since everytime I used the 3700 as an AP I would have to reset it to get out of that mode. Reset with a paperclip or hardreset 20/20/20 no longer work.
I changed the adapter settings manually and using the Windows10 diagnostic tools without success. With an Android app called Fing as well as with Netgear Genie app I see the 3700 and it's static IP address. I solved the hang issues by using a Netgear switch prior to the 3700. I works well, 1 week no hang ups!
Any help appreciated!
- Retired_MemberFeb 25, 2016
That router was one of the 1st dual band routers and had several problems. I had two, as for AP they never worked correctly. When I moved last year I junked them and 2 wndr4000.
There was a beta AP mode version. Also the correct way to reset that router is to Hold reset until power led flashes otherwise some settings are not wiped.
- Retired_Member
- GoombahzAspirantThanks Searay! I took your advice and upgraded the router to an R7000 and it works great!
