meda
Feb 15, 2016Aspirant
wndr3700 won't start up while lan cables plugged in.
Hi people, i have a wndr 3700 for a long time. lately, whenever i wanted to turn it off and back it on, it doesn't start unless i unplug all lan cables and wait for it to boot up. it's very stang...
- Feb 25, 2016
i think i've done it. i flashed it with ddwrt and now it boots up with every lan connection. so it probably was a software issue or a hardware one but ddwrt can handle or ignore it. i'll try official fw to see if old fw was just tired : )
thanks everyone.
meda
thanks for such a quick answer, searay. i have many wifi routers and ap's, it's not the issue. i just wonder what's going on.
i tried many cables and many devices, nothing has changed. i tried to update fw but it won't let it happen since it doesn't start properly with cables. also i tried tptf to flash it but no luck. she doesn't like cable when booting up.
Retired_Member
Feb 15, 2016If you can't load or reload FW from a wired PC to the router which is already powered up and working as you say you're doing it wrong. Either way not worth the time or energy to go any further with it.
Junk It!
