Parrothead
Feb 15, 2017Aspirant
WNDR3700v1 and WNDR3700v4
The Picture: * Basement/Home office: Xfinity wireless router/cable modem combination * Main floor: WNDR3700v4 (connected via hardwire Cat5 to Xfinity) Same SSID & Channels * Bedroom (2nd floor) - ...
- Feb 18, 2017
I just wanted to cicle back and let everyone know I neded up getting a pair of the Netgear PowerLine1200's for my delema and they appear to be working well. One is plugged in near the Xfinity cable modem/router and the other on the top (bedroom) floor where it's connected to my WNDR3700v1. Signal coverage and bandwidth is fine.
Thanks all,
-PH
William10a
Feb 15, 2017Master
You could use lan over power or just run a another lan cable which ever is the best way for you from the basement to the second floor and yes you maybe to use the wndr3700v1 as a access point for the second floor.
- ParrotheadFeb 15, 2017Aspirant
Thanks for the quick reply. I guess my question is, Is there a way for the 2nd floor router (the v1) to be TOTALLY wireless, and not run a wire up to the 2nd floor?
Thanks again,
-PH
- William10aFeb 15, 2017Master
Any wifi signal on the second floor at all?
- ParrotheadFeb 16, 2017Aspirant
Yes, but it is spotty.
-PH
