shelquis's avatar
shelquis
WNDR3700v2 One port not working
I've got one port that recently quit working. Is there any hope that somehow I'll be able to get it to work again? Or, when one dies is it gone forever?
  • Retired_Member's avatar
    Retired_Member
    Gone forever.
  • One of the LAN port? Only thing to check is with flash light look at the cable socket to see if any springy pins are out of it's slot or broken.
    Other than that not much else to check. Once I had that problem when some one knock over cable damaging the socket on my laptop.
    Had some difficulty to replace it but I managed to do it.  If you are running out of port, just get a cheap dumb switch. They don't cost much.
