JParez
Jan 05, 2020Initiate
WNDR3700v3 cant find WPS button
Where is the WPS button on this router? (Images will help)
Also, what is the difference between the GHz setting and how can I/should I change them to the higher setting?
I am trying to set up a wirelss printer. It is a Canon Pixma MX722. For the connection I need to press the WPS button on the router. I cant find that button.
I have a Windows 10 OS
While researching I found that the router has two different GHz 2.4 and 5. Which one should I use?
Found the answer in the manual!
http://www.downloads.netgear.com/files/GDC/WNDR3700V3/WNDR3700v3_SM_20MAY2011.pdf
- JParezInitiate
Well done. Always a good place to start.
