vernonls
May 07, 2017Star
wndr3700v3 guest network allows access to my private network
I have a netgear N600 WNDR3700v3 updated to the latest firmware update. I have connected the WAN to my home network and set it to obtain an IP automatically. So my home network is 192.168.1.x and s...
- May 08, 2017
OK, well I tried using the wndr3700v3 as a repeater for my exisisting Netgear N300 Model C2000 and it was pretty much of a bust. The manual that shipped with the wndr3700 was useless as it did not have anything about using it as a repeater. When I googled how to do it, I saw that it would limit me to only WEP encryption, so I decided that I would just live with the range limitations of having the main router in my office. And I could never get the repeater to work at all.
I think if I ever get serious about it, I will buy a pair of Orbi routers (master,slave), disable the wireless function of the router in my office. Then I could put the master Orbi and the slave in my living room so I could then have a really private LAN and wireless access for my guests. For now the guests will just have to do with less than perfect wireless in the living room.
vern
michaelkenward
May 08, 2017Guru - Experienced User
As this is a router, does the modem come into the picture somewhere?
Might be a conflict between the two.
