giannoni's avatar
giannoni
wndr3700V4 does not show the correct date and time
My router does not show the correct date and time . Is there a place where I can set those up ?
Many thanks
  • plemans's avatar
    I think its under advanced----->security---->schedule.
    • giannoni's avatar
      giannoni
      Thank you. Under Advanced/set up/schedule, I only have the possibility to change the time zone, not the date and time. Currently it shows Friday jan 2, 1970
      Do you know where the router gets the time ?
      • plemans's avatar
        it normally uses the netgear ntp server.
        How is the router setup? (modem/gateway)
        after setting your time zone, did you click apply?
