SamuelT's avatar
SamuelT
WNDR3700V4 loses 2.4 GHz band
About once a week my WNDR3700V4 loses the 2,4 GHz band i.e. there is no ourput and I need to restart the device to get it back.  The 5GHz band continues to be unaffected.
Is this a known issue ?  Is there a resolution other than buying a new router ?
  • also, firmware is the latest version available for download - 1.0.2.102
    • plemans's avatar
      Did it just start?
      Did it start after updating the firmware?
      What happens if you do a factory reset and reinstall?
