TDz86's avatar
TDz86
WNDR3800 Low download speeds wifi & wired
On Charter 60mbps, testing at half or less speed on computer wired and wifi. It seems to happen after I plug it in, if I reset it will test at full speeds, then later at half or less.   Screenshot ...
  • TDz86's avatar
    TDz86
    Apr 04, 2016
    Thank you for your timely reply.  I learned it was the Netgear Powerline 1200 adapters I had just purchased.
    The first speedtest I did with the powerlines came up at 60mbps, then they slowed down varying between 30-20mbps, I thought something had started throttling.
    I have returned the products as they were slower than my Wifi, unfortunately.  The topic can be closed, I was confused because they slowed down so drastically, but I guess that is normal.
     It was confusing, everything is running appropriately now.
    Thank you!
