RBusiness
Sep 03, 2015Aspirant
WNDR4000 LOGIN ISSUE
I have had our WNDR4000 in operation inhouse on a small LAN with about 15 devices connected, has been trouble free for q couple years until I added an Access Point yesterday and now can not log in to the Router. The problem is something I changed in the configuration when I was joy ridding through the config.
I can see the Router in the Devices and Printers and the IP address is correct, I can Ping it no problem but I remember turning
off an option relating to pinging.
The following is the message I get when trying to access the Router:
This Page Cannot be Displayed
- Make sure the web address http://192.168.1.1 is correct.
- Look for the page with your search engine.
- Refresh the page in a few minutes.
Any suggestions how I can get into the router would be appreciated. I do not want to do a hard reset because of the programming, We have about 15 devices on our LAN and can't be without the network so have not gotten to the point where I do a "Hard Reset" Thanks in advance for suggestions.
- netwrksMaster
Can you double check the IP Address of the AP? Or, try disconnecting the AP from your network, to see if things change. If it does correct itself, reflash the AP and reconfigure.. Maybe a duplicate IP Address?
- RBusinessAspirant
Thanks for your reply, now when I try to connect to an existing Linksys AP WAP54G that I could login to last night (192.168.1.245) it does come up with a request for User and PW and it does not like my password. I had no propblem with logging into it last night. I would not mind resetting the AP but will wait till I have exhausted all other options. I did unplug power and E-net cables and when it came back up tignal was good but still could not log in to it, at least it asks for user/pw where the Netgear does not even get to that point.
- RBusinessAspirant
by the way this AP has been on the LAN for a long time without a problem.
Plan on doing a power off reset on the Netgear in the morning.
